Radio Case - July 2025
pb_lonny
VK7AAL
Tasmania
The Evolution of My Radio Case: Practicality Over Perfection
As any serious radio hobbyist knows, finding the perfect case for your gear is almost as important as the gear itself. After years of trial and error—cycling through camera bags, lunchboxes, hard cases, and more—I’ve finally landed on a setup that works for my needs: rugged, organized, and easy to transport.
The Search for the Ideal Case​
My journey started the way many do: with high hopes and an overstuffed camera bag. It didn’t take long to realize that most off-the-shelf solutions weren't quite up to the task. Camera bags lacked structure, lunchboxes were too soft, and generic hard cases had either too little or too much compartmentalization.
Then came the Tassie Devil radio case I found at Supercheap Auto. It felt like the answer—just the right size, with decent protection and enough flexibility to suit my setup. For a while, it was perfect.
Until it wasn’t.
Over time, the hinges loosened, and a crack developed along the plastic frame. What was once a reliable carry solution began to feel like a risk to my radios.
Back to Basics: Tool Pro to the Rescue​
After retiring the Tassie Devil case, I went back to an old reliable: the Sistema with internal divider and removable containers (1.48L Bento Create™ TO GO™ with Mini Bite™). It’s marketed for a lunch box solution but it works incredibly well for radio equipment.
  • Durability: The hard shell offers excellent impact protection.
  • Modular layout: The divider and small tub allow me to separate antennas, chargers, batteries, and handheld radios—keeping everything in its place.
  • Grab-and-go efficiency: I can grab the case without worrying whether something’s going to rattle around or get damaged in transit.
Why This Case Works for Me​
My radio interests span VHF/UHF monitoring, ultralight DXing, and random wire aerial experimentation. That means I carry a mix of handhelds, antennas, coax adaptors, battery packs, and sometimes a notepad or signal log.
This case handles all of that with ease. I can swap items in and out depending on the focus of a particular outing, but the core layout remains stable and predictable. I know where everything is, and just as importantly, I know it’s protected.
Not Fancy—But Functional​
This isn't a Pelican case or a custom foam-cut solution. It's not waterproof or tactical. But it works. And for someone who values low-footprint, low-cost hobbies, that's exactly the point.
Sometimes the best solution isn’t the most expensive or the most hyped—it’s the one that keeps your gear safe, organized, and ready to use. This case might not win any style awards, but it's been one of the most functional tools in my kit.
