Radio ID alias
Can someone help me out with programming Radio ID aliases into these? I thought I was doing it properly however when I attempt to program it, I get an error.
That’s all. It said something to the effect of “Error: Unable to Program.” If I put it back to the previous version, it programs fine.
bkramm
Benton County, IA
In D 5 are you on member list settings?
Depending on the type of system if P25 you should put the radio ID in P25T
and give it a name in the alias column.
N6ML
Describe the steps that you are following to get to the point where the error message appears, and the exact text (or a screenshot) of the error message (not "something to the effect of").
Everything programs fine until I add "call alias" in the Member ID tab. Then I get the error.
N6ML
Try populating only one of the two columns - P25C or P25T, depending if it's for a trunked or conventional system.
bob550
Albany County, NY
If you've upgraded to FW ver. 1.31, you should be using PPS 3.16.21. You appear to be using the old 3.16.9.
Thank you. That was the issue. Turns out I downloaded both but must’ve only updated the firmware, and not installed the latest software
bob550
Albany County, NY
Also, since the new PPS version does not overwrite the old, It's best to uninstall the older PPS versions from your computer lest you accidentally use the wrong version.
