I have no plans at the moment. However, you can add a parameter to another shortcut to the program on your desktop or elsewhere, that looks something like this:
C:\MyData\RadioMasterXT\RMMasterXT.exe 2
That "2" or anything else put there like "CONFIG2" will create a second second set of settings in the Windows registry, and thus you could run two or more copies of the program at the same time, so long as you don't have the same com port enabled in more than one spot. I hope that make sense. Of course, you loose some of the functionality of having a single program, but it might help.
I originally thought I would do 4, but then realized the Media Center remote was somewhat limiting, so I cut the 4th one out. If there's enough demand, or I end up with 4 of them myself, I might work on adding a 4th.
Happy Scanning,
Ben
Ben
I was just looking for a program that would control 4 scanners at one time. I have a new USB cable arriving tomorrow and I wanted to be able to control a 996T, 996XT and two BCT15s. I was trying to figure out how to do a second install of the UASD Software. Since Uniden is way behind on the XT software, I’ve been using the UASD15 to control the XT scanner on my computer. One thing I do like about the UASD is the only controls and visual display of there virtual scanner.
I saw your post about the new software and tried it out. I must say, very nice. I know you just started this but do you plan on having it so you can see the display of all the scanners at the same time?? Also do you think you will include a 4th radio? Thanks again for a great program.
Dan
