Radio/Scanner Stores in Sacramento
blizzardx23
Dont know if this have been answered...I used the search function but have not found anything up to date...
I know chickenlips is gone...(I never been there, but I've heard that it was a good store)
Are there any places that deal with this kind of stuff? I'd like to pick up 1 or 2 NMO mounts today..but I cant seem to find any place that has them? plus, I dont know what brands are the best for that kind of stuff...any help?
avtarsingh
Cyberspace
bliz any place that would be around in sac would bone you for probably 20-25 each
for generic use i recommend Laird/Antenex MB8
unless you need a double shielded low loss type for 800 etc ..but this should work for everything you may need
Hutton Communications: Laird/Antenex MB8
list is 16 from hutton real world price is about 6-8 bucks each
this place has them for $6.39 each i have never dealt with them so i cant say anything good or bad about them - they popped up on search
http://www.wearecb.com/store/larsen-nmob-mounting-hardware-motorola-style-nmo-antenna-p-3313.html
ebay search antenex mb8 5 buy it nows.... ebay 130444599047
hope it helps i am out right now or i would give you a few i usually buy 25 at a time or so
if you have an acct - or access to an acct.... talley or tessco also good
blizzardx23
A lot of Sacramento seems to be 800...do I need double shielded? Im getting everything with the original hand held antenna...rubber duck...or ducky...whatever its called lol
I've found them on Ebay and google, but Im an instant gratification type person lol...it would have given me something to do today...How do you like the NMO? you havent experienced any leaking or anything? I know they use an O-Ring that prevents water from entering through the hole...any issues so far? Thanks for the links by the way, and the advice!
gmclam
Fair Oaks, CA
Sacramento scanning
When it comes to stores in Sacramento, there are a few, but the selection is lousy. Frys (both stores) have some radios. Some Radio Shacks have some radios. I either bought mine in the last century, eBay or ScannerMaster.
When it comes to accessories like antennas, you MIGHT find something at Metro Electronics; 1831 J street. You can also try HFE Electronics (formerly HSC Electronics) near Auburn Blvd & College Oak (4831 Amber Lane), but they are mostly a surplus store. We had a lot more places years ago, but with so many people buying online (and a lot of senior owners selling their stores) it is not like it was.
A lot of Sacramento seems to be 800... do I need double shielded? Im getting everything with the original hand held antenna...rubber duck...or ducky...whatever its called lol
Do you want CHP? How about conventional VHF and UHF channels? There are some being used, depending on specifically who you want to monitor. Certainly the basic agencies are all on 800......
If you're using a rubber ducky and want more than just 800 MHz, then use the stock antenna that comes with the scanner. For mobile I use a mag mount spec'd from 25 to 1300 MHz. For base I use a discone for general purpose scanning.
When it comes to coax, the "shielding" is not as much the issue as the line loss at the highest frequency you will be receiving. If you're running something like 20 feet of coax from the antenna to the scanner (like in an auto), the exact type is not a big deal. If you're running longer lengths, like at home, then it is critical. I am using an LMR-400 equivalent at home and then short feed lines of RG-6 that I actually bought at HFE. Very good stuff, even though it was surplus.
avtarsingh
Cyberspace
the point of double shielding is to help shield the user from 15-35 watts at 800mhz or higher
