RadioFeed 4.4 errors
mswells
WB6JLB
Phoenix, AZ
I am still getting a bunch of errors while running Radiofeed 4.4 for my feed.
08/14/19 1:37:10 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
at System.Net.Sockets.Socket.EndConnect(IAsyncResult asyncResult)
at System.Net.Sockets.TcpClient.EndConnect(IAsyncResult asyncResult)
at SourceClient.ConnectToServer(Object State) in SourceClient.vb:line 115
08/14/19 1:37:20 AM - Started To Connect To Broadcastify Server
08/14/19 1:37:25 AM - Unable To Connect To Broadcastify Server - Error Code 1
08/14/19 1:37:35 AM - Started To Connect To Broadcastify Server
08/14/19 1:37:35 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:37:45 AM - Started To Connect To Broadcastify Server
08/14/19 1:37:46 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:37:57 AM - Started To Connect To Broadcastify Server
08/14/19 1:38:02 AM - Unable To Connect To Broadcastify Server - Error Code 1
08/14/19 1:38:12 AM - Started To Connect To Broadcastify Server
08/14/19 1:38:12 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:38:22 AM - Started To Connect To Broadcastify Server
08/14/19 1:38:23 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:38:33 AM - Started To Connect To Broadcastify Server
08/14/19 1:38:38 AM - Unable To Connect To Broadcastify Server - Error Code 1
08/14/19 1:38:48 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:38:58 AM - Started To Connect To Broadcastify Server
08/14/19 1:38:59 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:39:09 AM - Started To Connect To Broadcastify Server
08/14/19 1:39:14 AM - Unable To Connect To Broadcastify Server - Error Code 1
08/14/19 1:39:25 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:39:35 AM - Started To Connect To Broadcastify Server
08/14/19 1:39:36 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:39:46 AM - Started To Connect To Broadcastify Server
08/14/19 1:39:51 AM - Unable To Connect To Broadcastify Server - Error Code 1
08/14/19 1:40:01 AM - Started To Connect To Broadcastify Server
08/14/19 1:40:01 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:40:11 AM - Started To Connect To Broadcastify Server
08/14/19 1:40:12 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:40:27 AM - Unable To Connect To Broadcastify Server - Error Code 1
08/14/19 1:40:38 AM - Started To Connect To Broadcastify Server
08/14/19 1:40:38 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:40:49 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:41:04 AM - Unable To Connect To Broadcastify Server - Error Code 1
08/14/19 1:41:14 AM - Started To Connect To Broadcastify Server
08/14/19 1:41:14 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:41:24 AM - Started To Connect To Broadcastify Server
08/14/19 1:41:25 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:41:35 AM - Started To Connect To Broadcastify Server
08/14/19 1:41:40 AM - Unable To Connect To Broadcastify Server - Error Code 1
08/14/19 1:41:51 AM - Started To Connect To Broadcastify Server
08/14/19 1:41:51 AM - Unable To Connect To Broadcastify Server - Error Code 9 - System.Net.Sockets.SocketException: No such host is known
08/14/19 1:42:01 AM - Connected To Broadcastify Server
08/14/19 10:57:00 AM - Disconnected
ProScan
Software Provider
Ontario, Calif.
What have you done to troubleshoot this? It could be anything on the near end including router ports, NIC cards, cables, ISP, etc.. or the far end.
mswells
WB6JLB
Phoenix, AZ
Tried a different wifi card...also tried connecting direct via LAN. Replaced CAT 5 cable with CAT 6. Rebooted everything, including Cable modem.
ProScan
Software Provider
Ontario, Calif.
Try reverting back to the version that worked?
I've seen people use a tool called "PingPlotter" that traced the problem to the ISP.
