radioshack pro 97
swat
well i like the alpha taging and the cb coverag the signal stalker but this thing is nothing like my pro 94 its like its the totaly opisit very very confusing for example i put the talkgroups i want in and others still come up such as i put in main channels and there tac channels still come over (I DIDNT EVEN WANT THOSE ) BUT WITH MY PRO 94 IT HAS THE CAPABILATY TO SEARCH ALL TALKGROUPS OR THE ONES I HAVE SET i am so confused right now someone help soooooooooooooooon................
swat
but i dont want to lock them out because. when i want to go listen to them them will be locked out.
LarrySC
Greenville, SC
I buy each scanner when it comes out. I only kept the 94 long enough to turn around and take it back. The secret to all scanners, this day and time, is software. You never hear the people with software complain about there scanner not working right. They may have an issue with some small feature they dont understand, but all is overcome when it's programmed correctly. Good Luck, Larry
dougjgray
Englewood CO
Well mostly the 97 works different, Read the manual on open and closed mode that should allow you to hear every thing (open mode) or just stored talk groups (closed mode). Also read up on subbanks for the IDS that should allow you to select certain IDS to monitor. I have a 94 and a 97 although I do like the 97 alot better there where some good features on the 94
swat
thank you so much both of you very helpful and that is true software is the main key and thanks again for the help
jpunix
Webster, TX
You need to "close" the bank to receive only the talkgroups you specified. Check page 79 of your Pro 97 users manual.
