sloop
I am now the happy owner of a surplus Radius GM300. I know nothing about this radio...can it be programmed to cover 2 meter frequencies and how hard is it to program? All I have is the installation papers and user 'card'.
Everyone's computer is different.While this may work for very few people, it won't work for most, unless all the stars are lined up in the sky, & there were 3 full moons that month. Seriously you are lucky that worked for you. I keep an old DOS machine to properly program old radios w/o a problem. Just like some people can use a serial/USB adapter, & others can't.Couple of things, one like others have said, make sure you have a VHF radio.
Second, I'll assume even if you have a VHF, it's not gonna go below 146 Mhz, so you will need to learn the shift key trick. The link mmckenna gave you has good explanation on how to ascertain what radio you have, and what the shift key trick is , but I'm not gonna explain it here, because you just need to read all the info on the Batlabs page about your radio.
Third, and people may flame me on this, you can use Windows XP and Windows 7 to program GM300's and GP300's. I've done it over a hundred times, and never bricked one. When you open up the software, you're gonna get some sort of error pop up. (me programming these is getting more far and few between, so I don't remember exactly what the error says) There will be a box on the warning, just hit Ignore. And you will be able to program the radio. The read and write will run real slow, (due to parity errors like crazy) but it will read and write the radio. The one thing that won't work is radio settings(I believe it's F2) such as squelch setting, tx power, etc, the software will freeze up.
But reading the radio, setting the freqs, setting the tones,and writing to the radio will work.
Maybe, depends on the exact model. Not hard to program, but the equipment needed to do it is not likely something you'll have laying around. You need a s-l-o-w PC with (ideally) a real serial port and able to boot up in DOS. It's a DOS program, doesn't usually run under a DOS window in Windows. You'll need the programming software (it's out there) and a programming cable.http://www.batlabs.com/gm300.html
Decode the model number first.
Second find a computer with a real serial port (doesn't actually have to be slow).First gen dual core machines are fine.
Third, boot dos (FreeDOS works).
Fourth, find the GM300 RSS somewhere and run the HDINSTAL program.
Fifth, get a programming cable hooked up and run the RSS.
Sixth, read the radio and most importantly save the codeplug before you mess with it.
Seventh, edit the codeplug.
Eighth, write the radio.
Ninth, enjoy.
One major problem is the hard drive needs to be formatted in a FAT16 or FAT32 format. DOS will not run on a hard drive that is not in the FAT16 or FAT32 format.
An item no one has mentioned yet is that you will need a level converter to go from the RS232 serial port levels to something the radio is looking for. Most people generally use a RIB (Radio Interface Box) that does the level conversion for you.
You can make your own or buy a used one or buy a new one. No matter which way you go, you will need some kind of level converter.
If you go look on Batwing Laboratories you can find cable information and info on how to build your own RIB.
