Radius M206 low band
merlin
DN32su
I unearthed an old low band Radius. Firmware is v20.00. Anyone know what the latest firmware version is ?
n3obl
Ø
PA
There was never anyway to change firmware on those old units. Probably the version of the eprom chip.
merlin
DN32su
Yea, I found the latest eprom bin offshore. V21.01 for this particular radio. Burning an eprom is no problem.
Had problems programming with RadMbl, then found a bad diode in my RIB. Building up a newer/better one.
Going to a larger EEPROM, edit the firmware, I might get 99 channels.
petnrdx
Hudson, FL
Over the decades, I found that it was MUCH easier to just convert all the RADIUS versions to MAXTRAC's and replace the firmware with either the ham version or the Canadian 99 channel MAXTRAC version. Ontairo Hydro. Add the larger EEPROM change the jumpers on the bottom of the logic board to accommodate the changes, re-initialize with 99 Ch MAXTRAC RSS and you are off and running. The Ontario Hydro 99 CH RSS is actually just an SP version of the MAXTRAC LAB. Even says Lab or DEPOT on the splash screen when you start the program. All that said, there just are not that many low band freqs to use. I did like the 99 ch version for the REPEAT / DIRECT button. You choose that option when initializing. But then you only get 50 channels. 50 with Rpt / dir was more that I ever needed. All that info is out there. FYI I have always found it more difficult to get RADMBL to work properly compared to MAXTRAC.
