Well the last DMR FW was on 7/07 but I was just making sure since the doc showed nothing of version info.
No it's not my doc. If you guys are happy with it then by all means submit it. I just think it's a little messy. They'll figure it out.
BTW, did you see the Radtel RT-6D Pro? It's pricey but I like it's keypad and overall design. It'll be out soon they say.
Yep, the document is messy.
The next time I or someone else updates it in Telegram, I will edit it according to your tips. Thank you.
I am a bit pessimistic that Radtel will address any of the bugs or requests.
I am trying to hint to Radtel and to other potential buyers (in Telegram) that before thinking about the RT-6D/Pro they need to fix their bugs and improve all the aspects of their Radio/DMR/CPS of the RT-4D. Hopefully they will not abandon the RT-4D completely.
I don't think it is worth it for them to have another similar closed-source buggy radio. They should model their product like the Quansheng that so the community can fix and contribute.
As far as I understood RT-6D is the same as RT-4D with a few hardware changes, but the Radio and DMR firmware, and CPS are the same.
I am fine with the low price of the RT-4D and its size form. I do not like large radios. I like to maintain a low profile, as you know
I really was only aware of the RT-6D without the Pro. Anyway, the additional GPS/APRS, Memory, Wattage Output etc. is not something I need, and for sure I won't pay 4 times for it.
In addition, I could not get the RT-4D to receive above 500 something MHz, (so their RT-6D advertising range is not true, if it is the same chip as RT-4D). They also need fix their advertising about Promiscuous mode. It does not include Time Slots which is a must.
I do like the middle knob to change channels and the multi-function buttons beneath the screen, if they are working, as with the Uniden scanners, for example. I do like the fact that programming is done via USB C at last.
Indeed the keypad layout with the 0 at the bottom is a "refreshing" look
