prcguy
- Joined
- Jun 30, 2006
- Messages
- 18,119
- Reaction score
- 13,878
Hi Dale,
I have a number of your products and they are well designed and manufactured, I hope your not taking my previous post as PAR bashing. My comment was more about the type of filter and its limitations due to the size, Q and cost vs the very closed spaced offending signal the OP has.
A new full size 1/4 wave notch cavity in a 5"-6" dia size would cost several hundred $$ minimum for a cheap one so if comparing new filters the PAR is a real bargain if the problem your trying to fix is within the specs of the filter. However, I'm a bit of a scrounge and am usually able to come up with surplus cavity filters cheap for many of my needs.
Hell to the Group,
I followed Tom's thread and have a couple of thoughts. Yes, a full sized cavity configured as a notch will have superior Q over our small filters. With that said, there is no other small filter on the market that achieves the selectivity of our filters. In Tom's case, we opted to make the filter response asymmetrical so it recovered from the notch more quickly on the RR side of the spectrum.
Likely the notch depth can be reduced somewhat and yield even less attenuation in the high side of the RR spectrum. We custom design each filter based on the client's requirements at no additional cost and include a Siglent VNA plot of that filter. The filter housings are small brass cavities with sealed piston caps and high end connectors-your choice all teflon dielectric. Our main business is milcom and aerospace. Their quantities allow us to price our amateur and scanner filters quite reaonably- that's my opinion knowing the amount of work that goes into machining and building the filters.
Regards,
Dale Parfitt
for PAR Electronics, Inc.
