RAS Programming
kc9gfr
Tilton,IL
Programming question
I have a XPR 7550 trying to program onto a system with RAS and radio ID Range.
I have the correct RAS as I can receive everything on the talk group.
Correct CC and time slot is correct.
TX/RX Frequencies and TG are both correct.
RX only is unchecked
Technically it should transmit on the system but no luck unless I am missing another setting
Anyone?
K2NEC
NA
Verify that you actually have the right key. Just because it receives does not mean it's the right key
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Anyone?
Double check you have a Transmit Group Call contact selected in the channel setting window. It's on the right side of the channel window, above the admit criteria.
rr60
Fuzzy memory says the repeater itself can be programmed to inhibit operations from group(s) of radio ID’s other than those permitted, this is an additional security feature in addition to RAS.
kc9gfr
Tilton,IL
I would assume since I could not receive until I put the RAS key in that it is correct. Can a RAS Key be receive only, maybe i'm missing a setting.
kc9gfr
Tilton,IL
I have also tried other radio ID that transmit and able to get through but when I program it with that ID still no go. Weird
