Raspberry ezscanner with SDR
angga_s
bandung
Hallo, i want to ask about "mount point" in ezstream config.
i'm try to broadcast my local airport communication with RTLSDR receiver, Raspberry & EZstream.
I previously used "Laptop Windows & Running K1PVG Scanner cast & no Have a Problem.. everything is OK.
but now im try with the same account, running on raspberry & ezstream the log show are :
ezstream: Connection to http://audio3.broadcastify.com:80/22556 failed: Login failed
currently my ezstream config is :
<ezstream>
<url>http://audio3.broadcastify.com:80/22556</url> <--- my mountpoint is correct?
<sourcepassword>HIDDEN</sourcepassword>
<format>MP3</format>
<filename>stdin</filename>
<svrinfoname>Husein Sastranegara International Airport (WICC)</svrinfoname>
<svrinfourl>http://www.broadcastify.com</svrinfourl>
<svrinfogenre>Scanner</svrinfogenre>
<svrinfodescription></svrinfodescription>
<svrinfobitrate>16</svrinfobitrate>
<svrinfochannels>1</svrinfochannels>
<svrinfosamplerate>22050</svrinfosamplerate>
<svrinfopublic>0</svrinfopublic>
</ezstream>
this is my public URL : Husein Sastranegara International Airport (WICC) - Live Aviation ATC
My Question Is : what is mount point ?
whether 22556 was the same as the mount point? if not.. whereis i can find my mount point.
thanks...
n0zo
Calera, AL
Compared to mine, yours is too short. Mine looks to be about 13 characters, it'll be on your technicals page for the feed, and should say feedpoint and start with a /
angga_s
bandung
Thanksss it's work... i found my mountpoint at the technical page... thanks W7JBG....
