Raspberry Pi Stereo?
TFerg53
Centralia, IL
I'm using a Raspberry to send my feed attached to a Uniden SDS200. If I add my second SDS200 to the feed using stereo cables, one channel from one SDS200 and the other from the other SDS200, will they come out Left and Right on my feed? I had two Unident 536's connected to an iMac and they worked fine, but a house fire destroyed that setup and I'm working my way back.
Thank you!
Tim
GlobalNorth
Fort Misery
You get two mono feeds. True stereo requires recording two channels and broadcasting both channels. I can't think of a public safety, utility, RR, aerodrome, etc. that would do true stereo comms.
a417
The OP is likely asking if he could merge two independant mono feeds into a single stereo feed with the audio split between channels.
TFerg53
Centralia, IL
You are correct. Have done it before, but not with a Raspberry, and am just wondering if the Raspberry input is stereo?
a417
The raspi input is stereo, as it is listed on the spec sheet. The raspi doesn't have the greatest audio path in the world, but for what you're using it for...should be golden.
