"Rdio Scanner" setup assistance
FFBillBlast
I'm not sure if this is the correct place to ask this question....I have looked around for a tutorial/educational video on setting up "Rdio Scanner" software. I currently run DSD+ Fastlane on windows to listen to p25 II w/no issues, but wish to run Rdio Scanner seeing it appears to be easier to use all the functions aval on SDR setup. I have minimal comp skills & was only able to set up SDR thru watching YT vids showing how to setup & operate its different functions. Shockingly, there is tons of SDR, DSD+, FASTLANE & etc tutorial/educational vids but I can not find any vids on Rdio Scanner & there are many ppl such as myself looking for vids on this & have no luck finding any.....if anyone could help me, as well as other ppl, we all would be extremely greatly appreciate it, THANKS.
FFBillBlast
Are you trying to setup rdio-scanner with SDRTrunk?
Well, I feel really stupid bc idk....as I said I know vary little about software/computers, my computer does save in the 1R file every radio transmission that go out on the system(agency) I monitor. It makes you probably question how the heck I even downloaded everything needed, program & make DSD+ work properly....I watched multiple YT vids from different ppl before attempting it myself. I have read the 'read me" directions for Rdio Scanner but I just don't understand or know where to locate everything in the complete zip file. So back to recording software, I looked thru all my files & don't see anything that says trunk recorder. So, maybe now seeing my limited comp abilities, you might wish to jump ship & I respectfully understand completely or I could take screen shots of my SDR/DSD+ files/programs for you to see what I have. The Rdio Scanner seems more user friendly for someone like myself, do you believe that to be true, I'm just curious?? THANKS AGAIN.
dave3825
Suffolk County NY
I run unitrunker,dsdplus and sdrtrunk. I use trunking recorder as it does both unitrunker analog and p25 (phase1) and sdrtrunk.
I download rdio scanner and did not get that far due to time constraints at the time.
FFBillBlast
After doing some research, I learned what SDR trunk is, I only run DSD+ Fastlane on Win10, I got rdio scanner downloaded & when I try pulling up the dashboard, it gives me an error screen. I see others have had the same error, so I'm still researching for the proper resolution.
FFBillBlast
Now I see what ur speaking of about time to setup, I got it pulled up on browser & trying to work thru all the configuring & set up, but not being comp wise, idk what most things like ssl certificates, apikey & so on....I will keep researching, learning & get it done(hopefully soon, lol).
dmchalmers
Good luck Around here! If your not all know'd up you on your own Newbe
noamlivne
I would recommend using SDRTrunk with Rdio-Scanner. That way you can maximize the listening experience, IMHO.
Try to set up SDRTrunk following the instructions on its github site. If you have issues, the site recommends you use a Discord forum and mailing list that can help you.
Setting up Rdio-Scanner with SDRTrunk can be easier. It is still quite a new program. Go to its github site and follow the instructions there (I also think there is instructions appended to the downloaded .zip file). In the github site there is a discussion board that may be of help.
dave3825
Suffolk County NY
Must of that is for streaming. What exactly are you looking to do?
I use trunking recorder with sdrtrunk and unitrunker and store 30 days worth of audio from 4 systems total that can be played back at any time from anywhere there is an internet connection. Playbac with trunking recorder is done thru a standard web browser.
