re-programming a deleted pre-loaded v-folder
moonies
seaford long island
Hello to all!! My question is this, How can you program by hand an empty v-folder with the contents of working memory when it consists of multiple state listings?? The pro-96 v-folders worked differently. You could delete a folder rename it and save it!!?? This gre psr500 makes me feel dumb!!!! I cant seem to store from the working memory without loosing the info!! Any ideas?? Do I have to use computer software??
Sownman
Santa Clarita Calif
From manual Page 87....
Saving Main Memory To A V-Scanner Folder
To save the current contents of your scannerʼs main memory to a
V-Scanner folder, press FUNC, then PGM to enter V-Scanner
mode, then press the Stor softkey. Use the  keys on the 5-
way pushbutton pad to scroll to the desired V-Scanner folder,
If the selected V-Scanner folder already contains data, you will
be asked if you wish to overwrite the existing data with new data
from your current version of main memory. Press the YES softkey
to proceed, or the NO softkey to cancel. If you decide the
overwrite existing data, or if the selected V-Scanner folder is
already empty, the scanner will prompt you to enter a name for
the stored V-Scanner. The scanner uses the text from Line 4 of
the Welcome Screen as a default name if the folder is empty, or
the current name if the folder contains data. You can provide
your own text here without overwriting the Line 4 Welcome
Screen text. Use the standard text entry method to type the
name you wish to use, then press the OK softkey. The scanner
will write the contents of main memory to the V-Scanner folder.
This will take approximately four seconds to complete.
