Realistic model 21-1642A manual
kc2asb
NYC Area
Well that's the end of that. Batteries must have exploded inside, if im hooked into 12v the one works but Batteries I get nothing. But I push the red battery test button on the front its bright as can be!? 🤷🏽
Strange. Is there any battery acid corrosion evident in the compartment? Probably not worth spending too much more time on it, though.
KF0AWL
Hobo
Iowa
Ya I can see a little on the bottom area. But can't see far enuf inside under to see what's up there. 🤔 might just open them up tomorrow. Figure it's not working anyway 🤷🏽 cant do much harm! Lol
KF0AWL
Hobo
Iowa
Well I decided not to wait and popped one open lol.
For future reference one screw top right corner and two inside battery compartment and a gental nudge the back pops loose. Once the back is off get a fingernail under the edge of the front and that pops loose from the plastic pins that hold it together..
Once the front is loose you will see the crystals, there is only one set and they are in slot A.
This one i see no corrosion top or bottom of battery holder and batt test light on front lights loud n proud but NO sound🤔🤷🏽
As i meantioned in have some crystals from a silent keys stuff, how do I know what channel they are for and will any crystal work? Or do they need to be same type that's in it? I enjoy fiddlin with stuff like this. Esp if i can make it work! Lol1000005814.jpg
mrweather
Looks like channel 14 crystals were in it: 27.125 MHz is for transmit and 26.670 MHz is for receive (455 kHz lower due to the receiver intermediate frequency).
I guess as long as the crystals physically fit you can use whatever you have.
KF0AWL
Hobo
Iowa
Ok so the numbers are the Mhz 👍🏻 this is a learning experience for me as i have never dealt with crystals before so thank you guys for the teaching!
