So you're probably wondering what these frequencies are good for. Allow me to remind you that Ham Radio is about the art of the possible, not the engineering of the reliable.
There are several modes of propagation that bear some investigation: First, you have troposcatter. This is a method the US military used during the cold war to build reliable connections over distances of as much as 900 km. Basically, you're scattering signals using the Tropospheric boundary with the Stratosphere. With enough power and directional antenna systems you can do impressive things.
If you live near places that have regular thunderstorms, you can scatter signals off of the upper layers of that thunderstorm and talk across distances of hundreds of miles.
All this works on bands as high as 10 GHz. Past that point you start seeing significant effects of signal attenuation from water vapor. There are compensating factors, however. As wavelengths get shorter, antenna performance becomes easier to come by.
I read recently of a new record distance for 76 GHz: New UK 76GHz distance record | Southgate Amateur Radio News
This is fascinating stuff. Also note that as bands go higher, bandwidths are significantly greater. The opportunity to send faster and faster data rates is certainly there.
Good Luck!
Good Luck!
