rebuild phase harness
thewrench002
old town, maine
well after afew years a great service. i re done the phase harness. still fun to hunt around for new signals.
prcguy
Interesting, the reflector should be flat or parallel to the ground over basically the entire US and maybe you can tilt it 10deg or so from vertical from your location when receiving sats close to the horizon. The main lobe off that antenna is not in line with the PVC tube, it actually has a null in line with the tube. The radiation pattern a doughnut that is about 40deg off the reflector surface covering a useable 20 to 60deg up in the air to cover most calculated UHF satcom orbital slots from the US.
thewrench002
old town, maine
that pic was when i was experimenting with seeing if there was any benefit to an angle on it. its on a flat surface now. when i clean the snow off it. lol.
