Sshalita
I know that the antenna has a great effect on receive (RX) quality, but I am wondering if there are any differences between the receiver engine/module contained in the various scanner models. This question is specifically for portable/hand-held units.
Aside from specific features, like trunking and other enhanced digital capabilities, do the higher end scanners have better RX capabilities (e.g., are they more sensitive) than lower-end models or do they all use the same RX engine? The same question can be asked for RX sensitivity between brands such as Uniden versus Whistler?
Right now I am using a BC125AT and am struggling to monitor Low VHF (39-45 Mhz for CA CHP). I upgraded the antenna to a Diamond RH77CA (thanks to reading threads on RR) and it helped, but it's still not great. It then dawned on me that there may be more sensitive receivers out there, hence the question. For what I am monitoring the BC125AT is sufficient, but I would consider upgrading if there was a more sensitive/powerful receiver.
Would be interested to hear comments.
