Have you ruled out intermittent connections in the coax, e.g. swapping the connections between the 536 and the other scanner?
How powerful is the 2-meter radio, and how close has its antenna been to the 536 antenna during keyup? Keying a transmitter too close to the scanner antenna can feed enough RF into the scanner receiver to damage it.
Is there any looseness to the BNC connector on the 536? Is it possible the connector isn't connecting to the scanner main board properly?
