Reception Pro-106 Vs. Pro-197
voxiso
Somewhere, Kentucky
I'm about to buy my first digital scanner, sick of not being able to listen to the Kentucky State Police. What I'm wanting to know is if there is a difference in the reception between the two? Also whats a good antenna to get for either of these scanners
gewecke
Banned
Illinois
I just bought the pro-197 and am very pleased so far. GRE as you probably know makes both,the pro-106/ pro-197 and the receiver are pretty much the same,judging by the fact that the same manual is used by both. However if you choose to use the r/s programming service they offer at some stores,then you might not get correct data need for ky.
I am using their 800mhz.6" duck on the back with an elbow bnc adapter and I am hearing most of the sites listed,although I'm sure I could come up with a better antenna if I scrounge around here.
If you decide you want the GRE versions of either radio then my buddy is a dealer/distributor for GRE and can probably offer you quite a deal! Tell him john referred you,and it might help.
His name is craig.
www.squadtechllc.com - Squad Tech LLC
Good luck!
n9zas
