Recommendation Requested - Inexpensive receiver for single frequency analog VHF 24/7 reception
lamarrsy
Rimouski, PQ, Canada
But if you take a 50/50 approach : eg :
half of the day on battery and listening
And overnight in the drop in charger to recharge
and continue monitoring,
(you said you wanted 24/7)
it should give an acceptable compromise.
a727469
Maine
Yes, that would work, but the uv5r has no way to power it except from batteries from charger so still an over charge possibility . Unfortunate it has no usb C or other direct connection on the radio itself.
Check out the Batteries and Accessories
On the miklor site..some great info👍
Omega-TI
Ω
Washington State
@AB4BF I noticed your avatar....
I have one of those flying on the wall in my bedroom. Nice to find another F4U fan.
AB4BF
EM93cs
At the risk of going off topic, my uncle was a Naval Aviator during WW2, flying Wildcats and Hellcats. After the Marianas turkey shoot and having 2 escort carriers sunk from under him while he was airborne, he had to land on the Enterprise but was relegated to another escort carrier. This carrier specialized in supplying Marines their F4U's with replacement planes and parts. At the time the navy wouldn't let Corsairs operate off of carriers because most of the naval pilots wouldn't fly them "for safety reasons". My uncle would catapult off the escort carrier and fly to a Marine island strip with a new or rebuilt F4U packed full of spare parts. Returning, the marines would put normal strength beer in every nook and cranny of the F4U and he would return to the escort carrier sitting on a case of beer and with two cases in his lap, flying "a not in the best shape" aircraft. He would land the F4U on the escort carrier and the shipmates would immediately put the plane on the hangar deck and get the beer off quickly. He did this countless times until an Admiral on a flagship spotted him doing this. He was immediately ordered to the flagship and brought before the Admiral.
Being drunk as usual, he stood before the admiral and dressed down for being inebriated, raised in rank and sent to Pensacola to train up and coming naval aviators how to fly off Essex carriers in F4U's.
In Korea, he flew the F4U's with four 20mm cannon and bomb racks to support Marines on the ground. One day they were doing the air support and a Mig flew past them shooting at them. He threw the throttle forward and caught the mig as it turned to make another pass and being able to turn quicker than the mig, he got on the inside of it and ripped it up with those 20 mm's. He did that 3 more times. He was never recognized for it because of the Navy's thinking that a piston engine plane can't shoot a jet down plus the Navy didn't want congress thinking that the Navy didn't need jets if a piston engined fighter could do the job.
He retired from the military in 1985 as a Lt. Colonel flying with the SC Air National Guard.
He always told me that the F4U Corsair was the best plane he had ever flown.
Omega-TI
Ω
Washington State
You may want to get a battery eliminator for your UV-5R to keep it in the car.
Per your recommendation, I will be getting one of these for the one I get for the car, then I'll use the extra battery for the other one. I'll probably end up getting one for the unit I leave on at home 24/7 once I can find a decent 3D stand to print up. The wire for the "battery eliminator" exits on the bottom, so it'll need a stand. So far I found one possible, but I'll keep looking for something better.
Omega-TI
Ω
Washington State
I wish I had known about << this one >> first off.
It comes with the bigger battery, a better antenna and a USB cable for charging, a much better deal. So instead of buying a separate "battery eliminator" and a home adapter for it, it was cheaper to just buy this package with essentially a free backup radio.
... so forget my previous message!
a727469
Maine
You may be happier with this one…much better display, usb c, etc etc …there is a comparison chart in the listing, but yes you might need to get an additional battery, but the radio is much better all around at an unbelievable price. Just my personal experience😉
Omega-TI
Ω
Washington State
Thanks for the suggestion, aesthetically it does look better, but the extra frequencies
Well...
... it already shipped, but I previously looked at that model and there were a couple of things that held me back...
... the first, some people have had programming issues with it and I didn't want to risk it.
... second there are reports of the screen washing out in direct sunlight.
... third, I kind of like the idea of 100% interchangeable parts between the radios (including the battery).
There is one thing that drives me TOTALLY BONKERS about this radio though, there is no way to lock out a noisy channel without deleting in entirely. Did the 17R fix that problem? Is so, that may be enough to get me to change my mind and send it back.
a727469
Maine
I believe the answer is no as far as a lockout feature like a uniden. Yes any screen like that will tend to wash out in the sun.
One way or the other, enjoy the radio!😁
Omega-TI
Ω
Washington State
Bummer on the lockout, but then again it's not designed to be a scanner (even though it picks up 90% of the stuff in the band I regularly listen to). It appears one can set frequencies to skip in CHIRP, so one could manually go to it when one wanted and have in highlighted in B while scanning in A. It's a funky work-around idea, but I'll try it when my cable arrives tomorrow.
I have to admit, otherwise it was an aesthetically pleasing radio,
prcguy
For anyone else in the future purchasing the genuine Baofeng cable, the CD is JUNK, go to miklor.com and download the Prolific 3.2.0.0 driver, it installs quickly, perfectly, and works like a charm!
I think the supplied Baofeng CD is geared more for steering our upcoming election than programming the radio.
Omega-TI
Ω
Washington State
Well contrary to what the radio snobs say, as a simple receiver, it's not bad and I'm happy with it.
Sure, it doesn't do one tenth of what my SDS does, but it was also less than one tenth the price!
Oh, the stand underneath it did not come with it, I 3D printed that today.
