Recommendations for mobile GMRS antennas
prcguy
Unfortunately, the Rig-Expert Antenna Analyzer was not cheap, a matter of fact, the cost was a very pretty penny, but I do not regret getting it. It has been a very valuable tool and appears to be a quality brand.
I never seem to be able to find the right meter on short notice, maybe I should get some more and stash them everywhere. Not shown is the Agilent RF power meter and attenuators I use to calibrate some of these.
DOAUSMC0331
A ground plane to an antenna is a bunch of sheet metal or ground radials right under the feed point. A ground strap to the chassis is more of a DC ground and not an RF ground unless it really short.
Great thank you does it matter if the ground plane is vertical or horizontal or just that there is one?
prcguy
For best transmission and reception for a vertical antenna its best to have a flat horizontal ground plane under the antenna. For most antennas except for a non ground plane type, any metal around the base of the antenna will help it achieve a good match, even if the metal goes a little vertical.
vagrant
ker-muhj-uhn
California
@prcguy - Which Agilent RF power meter do you use to calibrate your meters?
As for a mobile antenna on GMRS, I use a Comet CA-2X4SR which is available for NMO as well. I use it for amateur and MURS too. It is crazy wide banded and I use one for mobile scanners as well. It is not short though.
DOAUSMC0331
Ok another dumb antenna question I would be installing on fiber glass top. Would just a plain piece of 12x12 steel underneath it work like sandwiched up thier?
Yes, that would work. You'll want a 'thick mount' NMO to work with the fiberglass topper and the sheet metal.
I did this recently with some 800MHz antennas on some transit buses with fiberglass roof skins. Did the same thing with some UTV's with plastic roof tops.
K6GBW
Montebello, CA
Get some aluminum sheet and have a nice circle cut out of it, then epoxy that to the roof and drill a 3/8" hole for the NMO. Worked on our ambulances. The aluminum can be painted to match and people won't even see it.
