recommendations for mobile repeater
Project25_MASTR
TX-COMU
Texas
Quick report - so far the results are NOT encouraging. Kayn's prediction appear to be correct and the separation is not sufficient. In fact, so poor that I need a spacing of 11MHz before I get a system that would be usable. I had hoped that 8MHz would be acceptable but the repeater even on low power desenses the receiver far too much. I'm now on plan B. Kenwood repeater in a 4U rack, with a small fixed station duplexer, wrapped in foam in the 2U empty space, and a single antenna. Takes up far too much space, but appears to be a working solution.
If you have the ability/separation, I'd obtain a mobile duplexer. Epcom (El Paso Communications) has the best pricing I've seen so far on mobile duplexers...$215 before shipping. Getting it across the pond may be an issue though.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
I will suggest it again.
The Hytera portable repeater(you already own), with a mobile duplexer. If you need one, buy one of the Chinese ones, while they are a PITA to tune due to the screw and nut tuning 'rod', they will meet or beat the specs. of the Sinclair mobile duplexer they are a rip-off of.
paulears
Lowestoft - UK
The experiment with a duplexer does clearly show that I have to do it properly to get more than 400m or so range. My hope the split would add enough isolation was clearly wrong.
Is there a design difference that makes the mobile duplexers more expensive - externally, they appear the same, and I have a couple here, one UK built and one Chinese sourced that appear extremely similar. As the function of these and construction seems the same - has anyone cut one of the Chinese ones open to look at the engineering?
kayn1n32008
Sector 001
I do not think so. The probable reason the Chinese ones are so cheap is the cost to make them. Like I said before, the Chinese ones tune up as good as the Sinclair ones they are a copy of. I have had them side by side on a bench with test hear. The big difference is the way the tuning rods are built. The Sinclair ones use a compression nut, where as the Chinese ones have a threaded nut on a screw.
Sent from my SM-G870W using Tapatalk
Project25_MASTR
TX-COMU
Texas
The Chinese ones generally don't use silver plated connectors. Then again, some of the offerings from RFS (Celwave) don't either.
Project25_MASTR
TX-COMU
Texas
I actually just delivered two RF Technologies Eclispe 2 reciters in interop repeaters to a customer of mine. There's a new official mobile repeater based on the Eclispe 2 minus some features but will add the in-vehicle repeat capability for VRS operation. Originally I spec' d that job using Simoco SRM9005 radios configured for P25 repeat but they never would function properly in analog so they got swapped with the RFT options.
Sent from my SM-T713 using Tapatalk
kayn1n32008
Sector 001
Oddly, I have seen the Chinese mobile duplexes tune up as good as the Sinclair mobile duplexes. Agreed on the silver connectors... a bit over budget for the chinese
Project25_MASTR
TX-COMU
Texas
The irony, $100 more than a 50W Chinese notch duplexer (which is between $100-$150 less than an RFS or EMR) you can get a Made in Mexico notch only duplexer from El Paso Communications...with sliver plated connectors.
kayn1n32008
Sector 001
Interesting. Good to know.
prcguy
I've used and tuned up dozens of Procom notch only mobile duplexers and to me are better quality and tune up smoother than a Celwave. I think their made in Denmark and can be had cheap used.
prcguy
Pittsboro IN
tacticalrf.com/tech/antenna_isolation.pdf
I found this H vs V isolation chart, don't know who to credit.
If you have to use dual antennas try yagis vertically stacked if you can get away with the unidirectional
pattern.
RFI-EMI-GUY
I sold the Pyramid and Vertex units. Both work. The Vertex is simple with a lower cost.
Vertex Standard | VXR-1000
The Pyramid SVR series and the Vertex VXR are simplex crossband repeaters to use as mobile extenders. They are not duplex repeaters like th OP is seeking.
You can make a duplex repeater, but you need either an in band mobile radio or a second SVR or VXR to do the transmitting. And yes you will need a duplexer either way you go for in band operation.
I have to wonder how these cheap Chinese duplexers handle shock and vibration. Hat to be down on the Chinese, but those damn cheap radios. What are they thinking?
kayn1n32008
Sector 001
Almost be better off using 2 mobiles with a controller. Set it up so you have 5 watts out of the duplexer and put the 3rd mobile(that the SVR/VXR would be hooked to) on the link port. You would also be able to talk back before the repeater drops.
I would loctight the threads and I imagine it would be no worse than the Sinclair mobile duplexer they are copies of.
