HelixArray
Hi, I'm unsure if this is a hardware or software problem.
I'm wanting to add another scanner and record to the same PC. I've been using Xcorder for a few years now. I searched the forums and bought a handful of these cheap USB 3D soundcards. These cards work great. However, when I run two instances of Xcorder I just end up recording bleed over/cross traffic(for lack of a better term) from both of the scanners. Xcorder is seeing both of the seperate mic inputs as one, so I get two .wav files with duplicate traffic instead of separate mic recordings.
How would you guys record from two different scanners and get two different wav file outputs?
I'm on windows 7
Thanks, Helix
I'm on windows 7
Thanks, Helix
