Red Deer
elray4321
alberta, canada
At this time I do not have a trunking scanner, but am looking at getting a BCT15. The only trunking system I will be able to hear is Red Deer. I understand there are some issues with that system, and being able to track it. Will the BCT15 work? or am I wasting my money.
kolinab
Edmonton, AB
I'll be in Red Deer over the Christmas break and am going to program my BCT246T for what exists in Red Deer, hopefully RCMP if able - I haven't looked up to see if they're digital there or not.
So I'll let you know how I make out!
K
Jay911
Silent Key (April 15th, 2023)
Bragg Creek, Alberta
I didn't answer earlier because I don't know how the 15 performs, but I fear it will be the same problem as other scanners. My 396 won't do Red Deer, and I suspect the 15 (and the 996, which I believe is based on the same code/technology) won't track it.
The problem is that the system sees the trunk channels as 866.05, 866.55, 867.05, etc. The system knows the channels just fine because of the design of the programming that the radios use to communicate, which knows that for this particular system, channel 604 (or whatever) is 866.05, etc. However, to a normal trunk system, and to the Uniden scanners (at least the ones of recent times), that channel is actually 866.0625 - which is 0.0125 higher. The same goes for the entire 800MHz band.
It would be nice to know if a RS/GRE scanner could track the system. Or if a firmware update or future Uniden machine will work. I 'm pretty sure that UPMan (the Uniden product manager, who is a member of this site) is aware of the Red Deer system, because IIRC he participated in the thread a while back when we discovered this issue.
For now, I'm sorry to say that I don't think you're going to have much luck tracking Red Deer, unless you find a way to get around this channel/frequency mismatching.
elray4321
alberta, canada
Thanks for the info Jay, I knew you would have the answer. :)
I did buy the scanner, as it seems like a decent buy even without being able to track Red Deer City. Lots of other vhf/uhf traffic around. BTW congrats on the recent ham license, welcome to the club!
kolinab
Edmonton, AB
Thanks so much for that great explanation of what's going on. For now I'm just plugging in RCMP then!
Cheers,
K
