Reduce your request rate
belvdr
No longer interested in living
Using SDRtrunk and I receive the following error:
Code:
0221226 234713.261 [ForkJoinPool.commonPool-worker-3] ERROR i.g.d.a.b.b.BroadcastifyCallBroadcaster -
Broadcastify calls API file upload fail [503] response
[<?xml version="1.0" encoding="UTF-8"?>
<Error>
 <Code>SlowDown</Code>
 <Message>Please reduce your request rate.</Message>
 <RequestId>RDX65C5Y02FCPB2D</RequestId>
 <HostId>_removed_</HostId>
</Error>]
I don't see an option to reduce the API calls, and I believe it's related to the number of calls I'm receiving.
tweiss3
Is it time for Coffee?
Ohio
I haven't seen that one. I just pulled mine up and I'm not seeing any errors. I'm assuming MARCS? I have mine set for 25 channels (because that's the number of frequencies on this simulcast). Has it occurred more than once?
belvdr
This may have been a temp problem with Amazon. hopefully you aren't seeing it any further. Thanks,
I received one error yesterday, but so far nothing about reducing the request rate:
Code:
20221227 133543.014 [ForkJoinPool.commonPool-worker-2] ERROR i.g.d.a.b.b.BroadcastifyCallBroadcaster -
Broadcastify calls API file upload fail [500] response
<Error>
 <Code>InternalError</Code>
 <Message>We encountered an internal error. Please try again.</Message>
 <RequestId>70X4BQRD69ZP71C6</RequestId>
</Error>
