reformat scanners
blackgn6
illinois
anyone on here reformat scanners? I got a pro 96 still works but dont pick up much anymore and i dont know anything about it.
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
The first question to ask is what are you trying to hear?
Can you put in your local weather frequency, and if so, can you hear it? If so, the scanner is likely working.
This article from our wiki should get you started..(anything in blue is a link).
Getting Started with your PRO-96 or PRO-2096 - The RadioReference Wiki
There's links for the owner's manual, software and more...Mike
blackgn6
illinois
it all works but used to nonstop pick up police but not too much anymore so i just assume it needs redone
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
You still didn't say what you are trying to hear; and using a cable and software is probably the easiest way to 'reformat' the scanner. The article I gave you talks about this .....Mike
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
LOL You're dating yourself, zz (heh)
What he means is to clear the scanner completely and do new programming, I'm sure...Mike
JD21960
ILL-annoyed
--deleted-- years of same posts ... nothing will change
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
OK let's get off of DOS (Dumb Operating System) and get back to the question at hand - if you REALLY want to wipe the PRO-96, the procedure is outlined in the PRO-96 FAQ, a link to which is in the article I gave earlier.
Mike
