A Yagi antenna are not totally deaf in other directions, it has side lobs, so if that other site are much stronger then it will probably be picked up anyhow. Some Yagis from Amazon are great and if you have a portable scanner you can go up on your roof and hold the antenna in your hand and see what kind of signal improvement you can get compared to the scanners own antenna. If it doesn't seem to improve anything then simply return the antenna. I would first lock a scanner to analog mode and listen to the data signal, how clean it sounds and also look at its signal strength.
I live in a valley and have no transmitter sites in line of sight and have to use the most gain I can get from a Yagi pointing at a ridge. There are some reflections from houses when I point the antenna at other directions but not as much signal as from the ridge. Holding the antenna in your hand you can easily try different directions and instantly see the result on a portable scanner. If it seems to work then you can install that antenna on the mast.
Having to use the attenuator to get a clean signal doesn't sound good as it has a nominal attenuation of 22dB that are more than 100 times. It doesn't seem to be lack of signal strength that are the issue then but instead some sort of interference? Also try to enable IFX on the frequency, it's done to one single frequency so will have to be done to all voice channels in a trunked system, or actually only the ones that have issues.
When using only reflected signals to monitor will have that phenomena that the signal strength varies a lot depending of the weather situation and how the wind blows if the signal has to go thru trees. Using a SDS scanner for weak signal monitoring are not suitable as it has a lot of RF issues and other signals many MHz away will have an impact on reception. If this is not a simulcast system then try another digital scanner as you then don't need to handle different filters and interferences as it will have a more solid receiver performance.
/Ubbe
Thanks for the information Ubbe! That clarifies what I had read somewhere, but couldn't relocate the thread, about a possibility of a Yagi still hearing the other site (my local site) if I had it pointed the opposite direction, and the signal was strong enough to still be picked up.
Those are great ideas to try some testing. I do have a sds100, that I have a remtronix 820S antenna on, and ultimately have the filters set, and have no issues, like I'm having on the outdoor antenna, which is a dpdproductions 800 mhz vertical omnidirectional antenna. So, very strange that my indoor sds100 that's in what I would consider the worst location of the house hanging on a wall mounted clip doesn't have issues.
1 thing I've considered, and the only thing I can even possibly think is that I have the incoming powerline close to my outdoor antenna. It's probably 7-9 feet away. However, ive been told that powerlines wouldn't cause any interference. Problem is, I've never seen anything that factually says it won't. Another issue, the powerline is "in-line or level" with the antenna on height currently. So I am curious if raising it higher would get it above the powerlines height and do any better..? Not sure.
Other than that, I'm on the plains of Colorado. Really just flatland other than this valley I'm in and the mesa that's around 2 tenths of a mile behind my home and in-between the site and I. No trees in the way or even around really other than 1 in my yard, and farmground.
It's just way beyond me that my SDS100 with the remtronix is having no issue or problem indoors in a weird area, and a huge vertical antenna outdoors also tuned to the 800 mhz band is having the issues. I don't really want to do a yagi unless I absolutely have to due to pointing it at 1 site and not my local site, but thr other site has more of my listening as the range of it is way further than the database reflects. And it carries all but 2 talkgroups, which I would like to keep monitoring. So basically I'm stuck on what exactly the next step should be.
I have heard the Uniden BCD536HP is an excellent scanner. That's my goal is to purchase it next, if the reviews are correct. But that will be quite awhile down the road, so the ol' lady don't send me and my scanner packing.
The attenuator having to be on is hot and miss. Somtimes on, sometimes off. But due to the signal quality issue, the filter has to be changed fairly often. I just assumed from what I've read that if the attenuator had to be on, then that would mean signal is great despite needing to be at 53' on line-of-sight. But, nothings ever verified of that's a correct assumption or not. I have tried IFX also, it doesn't help or do anything for me.
Anyways, thanks again for all the advice and information, it helps tremendously!
Edit- for clarification I've been recommended
THIS Yagi for my situation. I am strongly considering it.
