Regency MX-4200
Thunderbolt
Global Database Administrator
Ann Arbor, Michigan
Back in the mid-1980s, AOR made the Regency MX-4000 and later on the MX-4200 scanners. Each of these scanners has an internal NiCad battery pack that recharges when the unit is plugged in a power source. Does anyone know a good source where I can obtain a replacement battery pack at for once of these units?
73's
Ron
morfis
AOR should be able to advise you. AORUK generally seem more knowledgable than the other offices. In the UK a source for battery packs is:
http://www.strikalite.co.uk/
There must be a US equivalent?
Thunderbolt
Ann Arbor, Michigan
johnmcanerney said:
I have an mx4200. Unless your model is different, I was able to install 4-nicad batteries. Unit has been working fine for over 2 years.
Mine has pack for four nicad betteries that are connected via 9-volt battery cable to another cable. I am almost half tempted to just build my own pack of batteries and buy a connector to match-up with the one inside my scanner.
73's
Ron
