Hi all,
I need a reccomendation for a reliable vendor of aftermarket power cables for 50w specta radios, with front mounted control heads. It seems like the stuff I've purchased in the past is woefully inadequate with regard to the gauge of the actual wire used (alot of insulation, only a little copper on the inside). This is causing radios to dim, reset, or have problems on tx (high power). I've observed the same problem with multiple cables, on multiple radios, hooked up to multiple power supplies, and shortening the cable as much as possible did help, but doesn't completely eliminate the problem.
P.S. I realize I can goto a radio shop and pay full price, but I can't quite afford that atm.
Alternatively, does anyone sell that odd connector on the back of the spectra? I could easily get the appropriate gauge wire and make my own harness.
Thx,
JB
Thx,
JB
