aschenavar
- Joined
- May 8, 2011
- Messages
- 77
Hi folks, got a head scratcher here. The following issue is on a fire truck, utilizing an APX8500 remote dual head setup. We have an O2 head mounted to the pump panel. Install was done by contracted Moto Techs. The O2 remote head has stopped working. Will not power on with ignition, or manually without as we were able to do before. I swapped a known working O2 head onto it with nothing there. I then took the non-working O2 head and put it in a known working position on another 8500 remote location and it will not work there either. I have traced as much of the harness I can under the truck and into the cab with nothing out of the ordinary located. The guys said they took the apparatus down a very bumpy road the night before it was reported to have stopped working. Our setups apparently only use the red, black and yellow doesn't go to anything within the wiring harness of the power cable.
Is there anything else I am missing to check before I call up the techs? Also, the main deck for this radio has power as the interior radio that mirrors the remote head has power and works fine.
