RES Clone multiple zones
comtech623
Good afternoon. At the risk of sounding ignorant, does anyone know how to, and if you can, enable the clone multiple zone option in the RES for the 5000's?
EMT_20
Paris, Texas
Zone cloning in RES is a great feature. Here are the steps.
1. Open RES
2. Load the existing code plug file you have on the computer that you wish to clone zones from to your radio. File > Open > the file that has the zones you want to clone.
3. Connect radio to computer and wait for RES to recognize the radio. The dot will go from red to green. You can at this point begin the cloning processes or hit Read Radio if you like, it will work either way.
4. Select from the menu bar, Tools > Zone Cloning > Clone Multiple Zones. RES will read the connected radio automatically at this point.
5. The Zone Cloner pop-up window will appear with the zones that are in the loaded file (Code Plug Zones) and the zones in the radio you just connected (Radio Zones).
6. Drag the existing zones from the Code Plug Zone table to the Radio Zone table. Dragging and dropping zones on top of existing zones in the radio will overwrite those zones. You can drag and drop zones in between existing zones in the radio. To select multiple zones you can use the Shift and Control keys when selecting zones to move.
7. Once you have moved the zones how you like them in the Zone Cloner window, hit the Write Zones button in the bottom right of the Zone Cloner window to write them to the radio.
That is it.
