Retevis Retevis NR40 Encryption not working
zmanley
Phoenix, Arizona
I recently bought a pair of Retevis NR40's. I programmed them and set up digital channels, with keys and turned on AES encryption. I made sure everything is synchronized between both radios - frequencies, encryption keys, settings. I made sure the firmware is current and the same between both radios.
When I am on a digital channel with AES ENCRYPTION, I get no voice. About 25% of the time the receiving radio gets a green light and the signal strength indicator comes on, so I know it's communicating on some level, but always no voice.
Is anyone else having these issues? Dies encryption work for ANYONE? since I've tried everything as far as troubleshooting goes (by Retevis) I'm having replacements sent. I'm just worried that the new radios will have the sane issue.
Thank you!
doriboni
Purchase an RTL SDR key and use the DSD-FME software with your AES key.
If AES is configured correctly, you can hear your voice through the DSD-FME software. Do the test with your two radios.
