K4APR
Some might have seen on the "Remote Control Head" thread that I am working on a kit that will extend the RH96 with a single CAT5 cable. The prototype boards came in today, I built up a couple of sets and I am pleased to say they work great!
The system is simple. Two small PCB (circuit boards), one at each end, the radio end and the control head end. Both boards interface to the various connectors on both devices ie. power, data and speaker audio. These signals are transferred between the boards via a standard CAT5 twisted pair network cable. The power is fed from the scanner end, where it can power both the scanner AND the control head. Once I can get some feedback, I might make provisions on the scanner board end for a single power input, with a "jump port" back to the scanner. This would only apply to the mobile version ie. BCT15, 996(XT), ect. The whole point is to simply the connections, reduce the cables and make it easier to use.
In the pictures below, you might think its a mess with all of the extra cable. This was only for the test, the final kit will come with 12" interface cables to go between the boards and the scanner/control head. The only cable that will not be short is the control head cable that comes with your RH96. This cable can be easily wrapped up, such as shown in the pictures.
In the picture, I am using a fairly short CAT5 cable of 10 feet, but so far, I have tested up to 50' without a single problem. I did'nt even notice an attenuation of the speaker audio. I would venture to guess I could go longer, maybe even twice as long.
Here are the pictures:
Feedback please!
Thanks!
Feedback please!
Thanks!
