Right side button not responding Motorola XTS 5000 Model 2
AOR1000XLT
Hello, I have the Motorola XTS5000 Model 2 Device that I purchased recently from a private seller so it's a used one. The right yellow button isn't responding when I press it. It is pressable and makes a sound when I press it but other than that nothing changes in the screen. The seller didn't mention any technical problems that the device has also he is not very knowledgeable about it. So I'm wondering if it's a technical problem within the system or the button itself or maybe I'm just using it the wrong way. Is it possible maybe the device is locked by a password? I attached a picture so you can see.
I am a lineman for the county.
Entirely possible it is not programmed for any function, or a function that doesn't apply with the current channel/zone.
Do you have programming software/cable that you can use to read the radio and check to see what that button is programmed for?
Asunakiyori
Lurker
Hiding in a Shed somewhere
Edit didnt see the circle, That button is for a data function. i doubt you'll have a use for it
The user manual identifies it as the app button TMS feature. Unless you are linking to a system with a phone/Text message patch, you don't need it
