Riverside County Fire Tone Assignments?
ScanFanEd
Southern California
Those that monitor Riverside County Fire (CALFIRE) are aware that they constantly change tone assignments, depending on the location of the station and/or call. It is well publicized as far as specifically which tone each tone number is, such as Tone 1 being 110.9, Tone 2 being 1230 and such. Just curious if anyone by chance knows which tone assignments are assigned to each repeater/tower, such as Elsinore, Santiago and such?
Thanks!
es93546
A Member Twice
Right Side of CA on maps
Thanks!
Do you want the entire county or a particular order. I have all the information for Cal Fire (151 MHz), but not the various commands that are mostly on 154 MHz.
techman210
San Bernardino County
“110.9, Tone 2 being 1230”
110.9 is a PL/CTCSS subaudiable tone and 1230hz is not.
You will have to elaborate a bit more for people to help you.
ScanFanEd
Southern California
Kingscup, thank you! I believe that is exactly what I was looking for. Am I reading this correctly, such as the Elsinore transmit site being Tone 3, which if I am not mistaken is 131.8?
Thanks again!
ScanFanEd
Southern California
Are you talking about the input tones used for each site?
Just curious if anyone else monitors RRU-1 West Dispatch via the INPUT freq of 159.360. From my specific location in Menifee, when on an HT, some tower sites are pretty weak, so when I am home I actually monitor the input instead of the output, without tones. I receive them much better this way. When away from home, I use the output.
Kingscup
Correct.
TONE 1 = 110.9 Hz
TONE 2 = 123.0 Hz
TONE 3 = 131.8 Hz
TONE 4 = 136.5 Hz
TONE 5 = 146.2 Hz
TONE 6 = 156.7 Hz
TONE 7 = 167.9 Hz
TONE 8 = 103.5 Hz
TONE 9 = 100.0 Hz
TONE 10 = 107.2 Hz
TONE 11 = 114.8 Hz
TONE 12 = 127.3 Hz
TONE 13 = 141.3 Hz
TONE 14 = 151.4 Hz
TONE 15 = 162.2 Hz
TONE 16 = 192.8 Hz
es93546
A Member Twice
Correct.
TONE 1 = 110.9 Hz
TONE 2 = 123.0 Hz
TONE 3 = 131.8 Hz
TONE 4 = 136.5 Hz
TONE 5 = 146.2 Hz
TONE 6 = 156.7 Hz
TONE 7 = 167.9 Hz
TONE 8 = 103.5 Hz
TONE 9 = 100.0 Hz
TONE 10 = 107.2 Hz
TONE 11 = 114.8 Hz
TONE 12 = 127.3 Hz
TONE 13 = 141.3 Hz
TONE 14 = 151.4 Hz
TONE 15 = 162.2 Hz
TONE 16 = 192.8 Hz
These are now the national standard tones. Federal natural resource agencies around the country are switching to these. Some had done so 3-4 years ago and some before that. I just researched Arizona and all the federal natural resource agencies have made the switch.
