RLF id's are the same on SERAM
MTL_Emergencies
Member++
Quebec, Canada
Y-a-t-il une raison pourquoi tous identifiants radio de RLF (tunnel Louis-Hipollyte Lafontaine) sur le canal Operations 8 du SERAM sont tous les mêmes (700238)?
Does anyone know why all RLF (LHL tunnel) radio IDs on the SERAM (OPS 8 channel) are all the same ID (700238)?
quebecradioguy
Quebec Database Admin
St-Eustache Quebec Canada
Easy. RLF is using DMR or Nexedge can’t recall. There is a bridge between their system and TG OPS8 on SERAM. 700238 is the APX radio installed on the bridge. We used to have the same setup in MRC Deux montagnes between 2 Montagnes/st joseph du lac DMR system and the RSP25 on TG 54005. The bridge was 4419005, the radio is now located in pumper 206
MTL_Emergencies
Member++
Quebec, Canada
Ok, so when they talk on the SERAM they're not using actual APX radios but they activate some sort of repeater to link the comm's between the two systems. Is it also why their voice sounds "windy" : Extrait radios?
