Romeoville PD
RoninJoliet
ILL
Romeoville PD as of last night has moved back to Starcom TG 1951 ,...Nothing heard on Will Co TG 2003 ,....correction TG 20003
RoninJoliet
ILL
Ok thank you , I checked the Starcom list and see all the designations for Romeoville which I should have done but they haven't used these TGs in a long time ,....
RoninJoliet
ILL
Romeoville is still dispatching on Scom TG1951 looks like it maybe for real not sure till they switch again,.. Maybe Will Co raised their dispatching fee,....
RoninJoliet
ILL
Romeoville has a special event today, there using a new TG 201 on the Will Co system with UID 38xxx which actually matches the EMA radio UIDs...I have also monitored TGs 202 and 203 used in the same SP-EV capacity,....
ILjim
10+ Years Listening
Wilmette, IL
Did WCSO Homer Glen switch to StarCom21 too? DB shows that all units that were on North Patrol have switched. If so, then that's very odd considering that other WCSO ops are on the County system.
RoninJoliet
ILL
You are correct, Will County cars are still on the WILL co south TG20001 , the only change was Romeoville PD who are now on Starcom TG1951,...When I read that statement it did not sound correct, it sounded like South dispatch was changed,...Maybe it can be corrected?
cubn
Search, Listen and Submit
Marion/Johnson County, IN
Here was the original submission:
North Patrol now abandoned, all north patrol units have been migrated to starcom21 TG1951 as of 9/5 8am.
From this forum thread, it looks like North Patrol is still used so I put it back to "Law Dispatch".
Was that correct?
RoninJoliet
ILL
Cuban you do great work and very much appreciated, it was just kind of saying WillCo Sherrif Patrol was moved also but was only Romeoville, the location of Will Co patrol units NSEW is very confusing as I'm west of WC and in Joliet but across the street north of me is Will Co also so all the divisions are questionable,,,,Excellent job cubn
ILjim
10+ Years Listening
Wilmette, IL
Was that correct?
No. I just checked Broadcastify Calls, and OpenMHz and the North Patrol TG is very quiet, except for a few key-ups by Romeoville PD units. On StarCom21, the only department I hear on Romeoville's TG is RPD. It would appear that WCSO Homer Glen switched to either Central or South Patrol on the County system, but I have yet to determine which one they're on.
werinshades
Chicago , IL
The Homer Glen entry under Will County will have to be updated. It's still showing they're using Central Patrol.
