RR Database???
gbeck41
Rector Arkansas
I want to let you guys know your doing a great job. I magine its a task to keep up with all that info. My question is, when you go to the county data base and it list Base and Mobile(if you want it to) freqs. Whys is it sometimes when you click on a call sign and at the bottom where the FCC loolup is and the freqs box list is, it shows some Mobiles that are not listed on the main page? I know that some Base and Mobile can have same freq. I like to get all the freqs I can when searching? Can someone tell why this is? Keep up the good work guys! This is the Greastest Site for Scanning in my opinion! Gregory.
Starcom21
IL /MO/Global DB Adm!n
The Call sign just contains everything the agency got licensed for, including every frequency. FB2's are repeaters, FB are bases, MO are mobiles, MO3 mobile extenders, FX1 is the repeater input frequncy, but often some systems don't have these, you just have to assume one of the MO is the input to the frequnency.
What you seeing listed in the radioreference.com database is the verified and/or contributed information, not just a flat lay-out of everything in the license.
Hope that helps
