RSP A with SDR TRUNK ERROR
bucknut937
Fostoria, ohio
Ive upgraded from the RTL-SDR to the RSP-A SDR black box so with it has came some errors for myself streaming to Broadcastfy Calls.
Channel Start Rejected Tuner Unavailable Phase1 Channel Grant Pri4 Circuit
https://www.radioreference.com/db/sid/6643
www.broadcastify.com
Node 4288: Ohio MARCS-IP: Multi-Agency Radio Communications (Site: Tiffin) - Live
BCFY Calls Node: Node 4288: Ohio MARCS-IP: Multi-Agency Radio Communications (Site: Tiffin) - Live
mtindor
OH/WV DB Admin
Carroll Co OH / EN90LN
It has both 700 and 800 mhz frequencies. Your single RSP will not cover both bands at the same time, so there will be missed calls and that error. You'll probably need to add a dongle to cover the 800 mhz freqs.
bucknut937
Fostoria, ohio
Thanks is there a way to make my RTL dongle only use it for 800mhz and RSP for the control band 774? I’m new to all this
bucknut937
Fostoria, ohio
I see the RSPA will cover the entire 700mhz with the 10mhz it says it does out of the box and the RTL will cover the one 800mhz on my site I know my other site I may stream is heavy on p25 traffic so it’s a lot bigger so 2 RSPA will be ideal for that which is the Findlay site
dave3825
Suffolk County NY
Yes. Click tuners tab. Click first dongle. Set Min and Max . Then click second dongle, and do the same.
mtindor
OH/WV DB Admin
Yeah, I'm sure that Tiffin site has more than five freqs anyway. Each standalone site has at least six. What's in the database is only what people initially reported long ago. So there are likely 2 800 mhz freqs.
bucknut937
Fostoria, ohio
I PM you the info from SDR trunk on this Tiffin Site for you
