Where exactly is the RTC battery in the 436HP?
Is it under a soldered shield and on which board.
I'm also seeing conflicting info regarding the charging of the RTC cell.
UPMAN says the 436HP must be on but another post says the RTC cell will charge regardless if the 436 is on or off as long as it is plugged into USB power.
Mine does seem to charge with the 436 off as it would ask me for the time each time I turned it on without USB power.
After supplying USB power but leaving the radio off, it is holding time.
So it appears the RTC cell is charging regardless if the 436 is on or off.
Possibly something in a firmware change I missed as I don't use my 436 often and had not updated the FW since 1.03 something!
Anyway, if anyone has any insight if the 436 now charges the 436 RTC cell if the radio is on or off would be great.
Also if anyone can give specifics as to the cells location inside the 436 would also be helpful.
I modded my 536 with an ML2032 rechargeable lithium cell and have not had any RTC issues with it but I know a ML2016 or ML2032 will not fit into a 436.
Thanks All
Thanks All
