thewraith2008
- Joined
- Nov 22, 2016
- Messages
- 1,867
I noticed a few months back that one of my blue RTL SDRs (RTL2832U+R820T2) had died.
I have a bunch of these dongles and you used to be able to get them for under $10.
With a little bit of shielding in select locations (not shown in image) and the addition of a TCXO (at the time I did them, they were about $4), these worked quite well.
Been curious, I wanted to see if I could locate where the fault was.
Turns out, the internal 1.2v switching regulator in the RTL2832U had died. There was no 1.2v present.
The switching regulator requires some external components to function. This voltage (1.2v) is then returned back in to the RTL2832U via a few different pins.
As a test, I wired up a LM317 regulator to output 1.2v and connected to the RTL2832U. (see image)
Looks ugly, but the dongle now works as expected.
Hope this is useful to someone who likes to try and fix things.
- I removed the 4.7uh inductor first to isolate it from the RTL2832U switching output.
- You should also isolate pin 27 and connect it to GND to disable the internal switching regulator (I didn't do this, to fiddly and it wasn't working anyway).
