RTL-SDR EAS Monitoring Help
dickie757
Wired
Out of range
.ogg use foobar2000 Ogg-Vorbis. If I don't use FLAC, I use ogg vorbis.
You might need the codec pack for foobar. I dont remember if it is built in.
itsj4y
404 Not Found
So I ended up just converting it to a .wav and using ffmpeg.
cmd prompt:
Code:
dsame --source sourcetest2.bat --text > alerts.txt
sourcetest2.bat:
Code:
@echo off
IF EXIST .\multimon-ng SET PATH=%PATH%;.\multimon-ng
IF EXIST .\ffmpeg SET PATH=%PATH%;.\ffmpeg\bin
ffmpeg -i .\sample-alert\WXR-RWT.wav -f s16le -ac 1 -ar 22050 -acodec pcm_s16le - | multimon-ng -t raw -a EAS -
output:
Code:
ffmpeg version 2025-01-05-git-19c95ecbff-full_build-www.gyan.dev Copyright (c) 2000-2025 the FFmpeg developers
  built with gcc 14.2.0 (Rev1, Built by MSYS2 project)
  configuration: --enable-gpl --enable-version3 --enable-static --disable-w32threads --disable-autodetect --enable-fontconfig --enable-iconv --enable-gnutls --enable-lcms2 --enable-libxml2 --enable-gmp --enable-bzlib --enable-lzma --enable-libsnappy --enable-zlib --enable-librist --enable-libsrt --enable-libssh --enable-libzmq --enable-avisynth --enable-libbluray --enable-libcaca --enable-sdl2 --enable-libaribb24 --enable-libaribcaption --enable-libdav1d --enable-libdavs2 --enable-libopenjpeg --enable-libquirc --enable-libuavs3d --enable-libxevd --enable-libzvbi --enable-libqrencode --enable-librav1e --enable-libsvtav1 --enable-libvvenc --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs2 --enable-libxeve --enable-libxvid --enable-libaom --enable-libjxl --enable-libvpx --enable-mediafoundation --enable-libass --enable-frei0r --enable-libfreetype --enable-libfribidi --enable-libharfbuzz --enable-liblensfun --enable-libvidstab --enable-libvmaf --enable-libzimg --enable-amf --enable-cuda-llvm --enable-cuvid --enable-dxva2 --enable-d3d11va --enable-d3d12va --enable-ffnvcodec --enable-libvpl --enable-nvdec --enable-nvenc --enable-vaapi --enable-libshaderc --enable-vulkan --enable-libplacebo --enable-opencl --enable-libcdio --enable-libgme --enable-libmodplug --enable-libopenmpt --enable-libopencore-amrwb --enable-libmp3lame --enable-libshine --enable-libtheora --enable-libtwolame --enable-libvo-amrwbenc --enable-libcodec2 --enable-libilbc --enable-libgsm --enable-liblc3 --enable-libopencore-amrnb --enable-libopus --enable-libspeex --enable-libvorbis --enable-ladspa --enable-libbs2b --enable-libflite --enable-libmysofa --enable-librubberband --enable-libsoxr --enable-chromaprint
  libavutil      59. 54.101 / 59. 54.101
  libavcodec     61. 31.100 / 61. 31.100
  libavformat    61.  9.104 / 61.  9.104
  libavdevice    61.  4.100 / 61.  4.100
  libavfilter    10.  6.101 / 10.  6.101
  libswscale      8. 13.100 /  8. 13.100
  libswresample   5.  4.100 /  5.  4.100
  libpostproc    58.  4.100 / 58.  4.100
multimon-ng  (C) 1996/1997 by Tom Sailer HB9JNX/AE4WA
             (C) 2012-2014 by Elias Oenal
available demodulators: POCSAG512 POCSAG1200 POCSAG2400 EAS UFSK1200 CLIPFSK FMSFSK AFSK1200 AFSK2400 AFSK2400_2 AFSK2400_3 HAPN4800 FSK9600 DTMF ZVEI1 ZVEI2 ZVEI3 DZVEI PZVEI EEA EIA CCIR MORSE_CW DUMPCSV
[aist#0:0/pcm_s16le @ 0000020aedae2e40] Guessed Channel Layout: mono
Input #0, wav, from '.\sample-alert\WXR-RWT.wav':
  Duration: 00:00:13.87, bitrate: 705 kb/s
  Stream #0:0: Audio: pcm_s16le ([1][0][0][0] / 0x0001), 44100 Hz, mono, s16, 705 kb/s
Stream mapping:
  Stream #0:0 -> #0:0 (pcm_s16le (native) -> pcm_s16le (native))
Press [q] to stop, [?] for help
Output #0, s16le, to 'pipe:':
  Metadata:
    encoder         : Lavf61.9.104
  Stream #0:0: Audio: pcm_s16le, 22050 Hz, mono, s16, 352 kb/s
    Metadata:
      encoder         : Lavc61.31.100 pcm_s16le
[out#0/s16le @ 0000020aedae3740] video:0KiB audio:598KiB subtitle:0KiB other streams:0KiB global headers:0KiB muxing overhead: 0.000000%
size=     598KiB time=00:00:13.87 bitrate= 352.8kbits/s speed= 555x
and it hangs there until I ctrl+c. After that alerts.txt populates with the weather message. Not sure if it is going to be like that using the sdr dongle or if it't just because of ffmpeg or the sample file
