Saber Transmit Problem
kc9kfj
Hello,my Saber is programmed with some frequencies and pl's that my church uses.Here's
the problem;when I transmit with one of the church radios my Saber recieves the signal,but when I transmit with my Saber,the church radio does not recieve the signal.The correct frequency and PL tone is programmed in the Saber,and other frequencies (ham radio) work fine.I verified that the correct frequency and PL tone is transmitted using my scanner.Any ideas?
kc9kfj
If it helps,the church radios are Motorola Spirit mu11c.
zz0468
Banned
My first guess would be that something is programmed wrong. But you say that you verified it's not, by listening to the scanner. So, that really leaves us nothing to even guess about. Double check the programming. Try different radios and give yourself a sanity check. Does the church radio hear ANYTHING, or is it just deaf to your saber? Are one or the other radios programmed for a repeater frequency pair? Use some logical troubleshooting skills and figure it out. We can't with what little you've given us to work with.
WX5JCH
Banned
Elk City, Oklahoma
Would not the 466.650 be a input to a repeater? say like 461.650?
zz0468
Banned
Yes, normally that would be true. But who knows what people are going to do...
kc9kfj
I just found a frequency guide for the Spirit radios,and found out that the the wrong frequncies were programmed in the Saber.The correct frequncies were 464.550 and 467.875.The wierd thing is that I can hear the church radios on my Saber.Anyway thanks for the help.
