R7 Muting Tones
Muxlow
Super Secret
Middlesex County
On a R7 on an analog fire paging channel with no PL and no quick call set when a page comes over the radio is muting the tone section of the page then opens back up for the voice portion. No issues with a 7550 programmed the same.
Any setting or audio profile section that needs to be changed from the default to unmute this? Want to hear the actual 2 tone and single tones when pages come over but for whatever reason this R7 is muting that section of every page and no clue why. Never ran into this problem with any other radio types before
EuropeanUser
I can’t remember exactly where the setting is but enable side tone either in the system or in the channel.
Muxlow
Super Secret
Middlesex County
Every setting i can find is exactly the same as my 7550 so im leaning its gotta be some other setting thats not channel specific
Programmed hundreds of kenwood, hytera, harris and moto radios and havnt ran into this issue before and my first time touching a R7
Monitor type is open squelch not silent.
Channel settings - squelch is normal, audio enhancement is set to non. Paging freq entered and set for rx only and no PL just set to csq and no signalling system selected. Tried non and quick call didnt make a difference.
Audio profile apparently i have set to disabled.
AF suppressor checked same with RX audio level. noise suppressor is set to enhanced audio
Under alerts i dont have disable all tones checked
EuropeanUser
Right. I get it now.
So it is basically a regular analog channel with carrier squelch and it still mutes the tones before the voice transmission. That is weird. I can't think of any reason it would do that, but I can do some testing tomorrow when I'm back in the office. I'm pretty sure mine does play the tones, but I don't have mine set up like yours.
Muxlow
Super Secret
Middlesex County
Yeah if you wanna have a peek at your settings and compare.
I dont have a default codeplug for this radio or id kinda do a factory reset and load that in and start over.
Im going to toss another departments paging channel in and see what that does, they also dont use a PL
ramal121
Lots and lots of watts
Calif Whine Country
The only thing that comes to mind is DOS muting. What are the tones? Maybe go to DOS settings under MDC and twiddle with those looking for any change. Does DOS still function even though there is no optional signaling? I can't answer for sure.
Muxlow
Super Secret
Middlesex County
Put another dept in and works just fine. Tones came over no problem but for whatever reason in my county its muted
Dont understand THAT at all.
Only thing i can think of is this radio is 12.5 only and the paging channel i need is 20khz and the ck one is 12.5
But iv got 12.5 set in all my other radios or 25khz and works just fine. Even setting my test channel as 12.5 and transmitting on 25 it comes over the R7. Rather confused.. but thats sorta what im leaning twards is bandwidth? But then why would it mute the tone and not the voice..
Muted audio
Non muted
ramal121
Calif Whine Country
Maybe so. When I check a radio one thing I do is modulation acceptance. I inject a signal into an analog channel and then increase a 1kHz test tone until the audio blanks out. I find this happens from a few kHz above the bandwidth to maybe right at the bandwidth limits. Kind of a down and dirty way to check IF filters. Varys from radio to radio.
Maybe the solid tones are a bit too hot for the radio running narrowband. Voice could be at a lower deviation and if it did cause problems would only be on peaks.
Muxlow
Super Secret
Middlesex County
Going to program my hytera for each bandwidth and set off a tone and see what happens
Had a major fire today and 6 different stations got paged out and same thing for each. Muted
Yet other county for the pager test of 3 stations worked just fine. Cant think of anything els other then the paging transmitter is set to 20khz and the R7 just isnt having it
Muxlow
Super Secret
Middlesex County
Well that didnt work out.. Programed 12.5 20 25 sent a page and all came over the R7 so now im really stumped...
Copied the non working channel, pasted it and changed the frequency and seems to work just fine for the other county and on my test channel even using the same tones for the depts who went out today. Works just fine on my channel but not coming over the repeater from dispatch.
Going to add a station and select that whenever a dept gets toned out. They get 3 pages so by the 3rd radio should be updated and see if selecting quick call with that depts tone set can either hear the tone itself or the radio alerts for the page
FW is R02.25.01.1002
with CPS 2.0 ver 2.155.262
EuropeanUser
I was not able to replicate the issue. I always hear the tones.
Muxlow
Super Secret
Middlesex County
I set my hytera HP782 to 12.5 20 and 25. Set tones off and R7 hears them.
R7 will her 2 other counties tones who transmit in 12.5 and 25khz
R7 will NOT hear my counties tones that are transmitted on 20khz from the repeater
Tried every setting i can think of and nothing seems to want to work for it.
Hear them just fine on the XPR7550 and Hyteras and Harris
Even tried the 7550 programmed in narrow band and it still plays the tones but the R7 just will not do er. Very strange
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Set it to 25khz. It might not like over deviation(25khz) when your receiver is set to narrow(12.5khz)
Muxlow
Super Secret
Middlesex County
This R7 only has 12.5 option so cant change it.
When i set my hytera to 12.5 20 and 25khz and set off a tone the R7 hears it but im thinking thats because im 2.2 foots away from the R7
Maybe tomorrow during pager testing ill go sit beside the transmitter site and see what happens then just for the fun of it to see what happens
How much is the wideband option for the R7? Didnt the XPR series offer it for free back in the day?
Muxlow
Super Secret
Middlesex County
Problem solved. Got the wideband enabled and now its hearing tone.
Paging channel is 20khz and apparently the R7 is super picky and would mute only the tone section of a quick call. Now thats its changed from 12.5 to 20khz its working fine n dandy
My XRP7550/6550/5550/4550's could care less being left on 12.5 they all seemed to work.
kayn1n32008
Sector 001
20KHz(4.0khz deviation) or 25KHz(5.0khz deviation. I'd be surprised if your paging channel is not 16k0f3e in Canada. If it is, then it's 5.0khz deviation and not 4khz
Muxlow
Super Secret
Middlesex County
Other counties are 12.5 or 25 and for whatever odd reason mine is using 20khz least thats what all our radios are showing when i read them.
Odd that the XPR's and Hytera dont seem to care if the channel is set to 12.5 or 25 it still unmutes the tones
And why would the R7 mute the tone portion but not the voice following the quick call.. Wacky but all fixed meow setting er to 20khz :)
