Not even remotely true.The Uniden BCD325P will do everything a SDS100 will do . Without battery problems .
If your scanning is either searching or scanning pre programmed frequencies .
Problem is both the BCD325P and SDS100 are prohibitively complex to program by hand . I attempted using the software and laptop . Managed to figure out how to search and hard grand success logging frequencies.
As to programming frequencies into channels , banks of what ever . Total failure and much frustration.
The battery on my SDS100 bloated on its own while the radio was sitting abandoned on the shelf 3 years ago . Sent it to service and to their credit they did repair the radio’s lack of sensitivity and they replaced the battery . The battery has been fault free for the past 2-1/2 years
One major issue, on large statewide trunked systems, you very quickly hit the limits on systems, etc.
On Ohio MARCS, for instance, you must create multiple systems whereas with an SDS, you can do it with 1.
Using location is doable but a real pita when programming.
I use mine for very localized, limited scanning just around town, or something specific like rail or airshows.
