SDS100/SDS200: **SAFETY ALERT** SDS100 battery severely swelled
N0ZQR
Nebraska
But if they split on their own, just laying on a table, what can you do about that?
I had one do that to me the other day, surprised the heck out of me!
Wish I could download a picture of mine, but they say the file is too large.
Ron
richardbritt
State of NC
Northeastern NC
Those are lithium ion I believe. You might want to check and make sure. You might not want to keep the swollen ones inside your house. Don't throw them away in the trash or dumpster either. They self combust violently if heated or compressed. I am on one of the state regional Hazmat Response teams. If they are not lithium then disregard but once one of the cells starts to burn, they give off their own hydrogen and rapidly go up in seconds. NIMH and Nicads don't do that. That's why I own a 436 and use NIMH batteries.
As a follow up, I found this online about the lithium polymer batteries, "they have good resistance to thermal runaway and are less likely to catch fire or explode if damaged". They are made with gel not liquid.
Ubbe
Stockholm, Sweden
I'm pretty sure it's only one or two of the cells that have expanded and they are connected in parallel by a metal strip that can be cut to remove the bad cells and you can continue to use the battery at a lower capacity, suitable to be used at home. I had one cell expand and the other two have been fine for three years now.
/Ubbe
darkness975
Latrodectus
Ron
Take a screenshot of the picture. Thats how I get around that.
djeplett
NE Wisconsin
I run my SDS100 on AC pretty much all the time. As a result since the first battery swelled on me I charge mine up to only about 60% or so now and then run the radio off the micro USB port since that one does not charge the battery. When I decide to take it on the road I will charge it up to 100% before leaving. No signs of swelling now in the years since I got a replacement battery for the original that swelled. I have to do almost the exact same thing with my laptop, too. Only I actually open it up and remove the battery after it's been charged to around 60% and then run it off AC without the battery inside it. I had my original battery in my laptop swell so bad that it actually broke one of the threaded areas in the case and now the screw in that area will no longer hold anything. I've had to learn the hard way.
Ubbe
Stockholm, Sweden
It doesn't seem to be related to how you charge it. People have had a battery tucked away in a desk and after a long period of time when taking it out it has swelled. There's probably something about impure chemicals or something, a low quality production line and it's just bad luck if it happens. I charge my battery the same since I got it and only one cell has swelled and the other two cells in the fat battery have not swelled one bit and I still charge it the same way since the first cell swelled.
/Ubbe
DCHarris
I have had FOUR batteries swell like this. All occurred while in the charger, but were not being charged at the time. The first two were the one that came with my SDS100 and a spare one I bought at the time, both having lasted several years and which occurred just a few weeks apart. When the first one went bad, I bought two more, both of which went bad within 1-2 years. Currently have batteries #5 and 6. The first three all occurred in my original charger; when I ordered #5 and 6, I ordered them both as a set, with chargers. My 4th battery went bad in one of the new chargers.
samsat
San Diego
I run my SDS100 off external power and if I need to go portable I just plug in a powerbank. Tired of having to continually deal with the poor battery quality.
Ubbe
Stockholm, Sweden
To be able to replay a conversation you didn't quite get are valuable to me and running without a battery will for some reason disable that feature. I would like Uniden to allow replay recordings even when running on only external power. There's no real reason to disable it, claiming external power gets unintentionally cut off too often that then will corrupt the file system on the SD card. Mobile scanners without a battery, like SDS200 or BCD536, can be run on external power from a wiggly cigarette lighter outlet that have a much higher risk of cutting power, especially when you turn the ignition key and start the engine.
/Ubbe
