Sample Motorola Simplex Control Station
Brad_M0JXR
Bristol
I have had difficulty getting the Control Station operating over simplex .Using DP4801e
Setup is Laptop running RM for OTAP .
All reading and writing directly via USB RM is successful .
1- Set persistent routes in cmd .
2-Can ping radio ID-23401 and response is received in cmd correcty as below .
C:\>ping 12.0.91.105
Pinging 12.0.91.105 with 32 bytes of data:
Reply from 12.0.91.105: bytes=32 time=2171ms TTL=63
Reply from 12.0.91.105: bytes=32 time=3536ms TTL=63
Reply from 12.0.91.105: bytes=32 time=2280ms TTL=63
Reply from 12.0.91.105: bytes=32 time=2262ms TTL=63
Ping statistics for 12.0.91.105:
Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
Minimum = 2171ms, Maximum = 3536ms, Average = 2562ms
3- Double checked OTAP passcodes etc .
4-Have also added additional 192-168-11-1 to persistent route dedicated for Control Station - however no difference .
Has anyone have a working codeplug for a control station and simplex radio that I can check all the settings against .
The RM will just not see the radio so remains in "Waiting for device"
Could well be firewalls but would like to check all other criteria against a working setup before changing ports on laptop .
Thanks in advance
Bradley M0JXR
