San Bernardino County System 8
krazybob
Lake Arrowhead, Southern California
I'm not sure what's going on. When I program using the frequencies here I am unable to trunk track using an older Uniden 780. But if I use the frequency set from the Southern California Frequency Directory from 2008 as I have long since done on my streaming radio and in my truck, everything appears to work fine. I've locked everything out except the CC channels and decode properly as well. The CC frequencies haven't changed. I place conventional frequencies in the bank but that has never affected trunking with the exception if ICIS.
Any help would be appreciated.
forums manager
Super Moderator
Staff member
Super Moderator
Posting to the GenScan forum isn't going to get you a lot of help. I've moved your thread to the CA LA/Inland forum.
Please review Sticky threads before creating threads in the future. Thanks.
zz0468
Banned
Not having access to your 2008 data, I have no way of knowing if there is a difference between that and the database here. What are the actual frequencies you have plugged in as control channels?
zz0468
Banned
Since you haven't returned to the thread, I'll assume that you resolved the problem. I'm curious as to what you found wrong.
